Page 40 of 121 FirstFirst ... 30 38 39 40 41 42 50 90 ... LastLast
Results 391 to 400 of 1209
  1. #391
    Looks like those tires are a little skinny for the wheels or is it just me?
  2. #392
    Orono, ME
    www.stancenation.com
    2012 Honda Civic Si - DD
  3. #393
    May 2011
    they are stretched, but im running a 275 on an 11 which is within the factory specs on the tire, not super stretched like a 205 on a 10.5 or anything like some people do. Cant really run any larger on a gto without modding the suspension/fender tubs anyhow, so im not really sacrificing a lot of width with a 11.2 inch tread width. I wanted larger lips so i had to stretch the tire on there. Since the falken i have on here now comes with a "rim protector" feature in the sidewall, it causes it to poke a little, which im not really into, and some other tires dont really do..but im willing to deal with it and have the sticky tire i run..
    www.canibeat.com/2010/06/blacklist-ed/
    http://www.stancenation.com/2010/09/...vated-assault/
    Easily swapped to my other wheels if you are into a different look though. Just will not even remotely handle as crazy as it does with the ccw's. gotta raise it up about an inch though, but heres a test fit to give you an idea.. The fronts arent pictured but i run gto spares with mh skinnies and 1 inch spacers.
    The poke did not look as bad on my r888 toyos. but those tires are like 800+ a pair and last less than 5000 miles.
    most of those pictures are of it slammed on the ground at car shows. those toyos are hands down the nastiest tires ive ever ran. You get them to 150-200 degrees, and they will suck your eyeballs out of your head when you shred a turn.
    seeing those old pics remind me of what my car looked like when it was slow and not a dented up pile of garbage. LOL.. Well not AS dented up. Pulling the fenders over 1.5 inches from stock is pretty difficult to do without skim coating the fender and repainting it in the end. The spot welds for the quarter to subframe turn into dimples after you roll over them so many times, hence the ripples in the fender lips.
  4. #394
    Sep 2010
    McPherson KS
    Personally I'm not a huge fan of the whole narrow tire look, but I will say that car is about hella sexy. Also I love the Commodore front end.
  5. #395
    May 2011
    thx! Its not for everyone, but ive got different wheels for each extreme! lol..
  6. #396
    May 2011
    Buffalo, NY
    [QUOTE=BLACKLIST;439912]
    As i was reading this, on your mods list it says you have "Pace Shitter" headers. Is that like a porta-john in the back seat? lol
  7. #397
    May 2011
    lol, as in rusted out 250 dollar pace setter headers. lofl..
    Im getting ready to sawzall them off instead of taking the time to remove them, lol.. And swap to 1-7/8 kooks for my blower setup.
    also, That mods list is really old honestly.
    Mild portmatch and polish on 243 heads
    LG G6X3 camshaft
    Rollmaster double roller timing chain and billet gear
    SLP oil pump
    Manley dual valvesprings
    Manley titanium retainers
    Comp magnum push rods
    Fast 102
    Fast 102 dbw throttle body
    Duspeed OTR intake with ls7 maf
    Torrid fuel rails
    Weldon regulator
    Weldon pre filter
    Aeromotive pump filter
    Aeromotive a1000
    -8 return. -10 feed
    Behind bars race cars custom 18 gallon sheet metal cell with sender -12 feed/-8 return/vent
    47lb ev6 injectors
    Pace setter ceramic 1-3/4 long tubes
    catless mids
    spintech 2.5 mufflers with turndowns and spintech x pipe
    trick flow air intake
    Katech tensioner
    ASP under drive pulley(wobbley unbalanced trash, now have fluiddamper thankfully before breaking a timing chain)
    A/C delete
    Monster 3200 lb race pressure plate
    RAM sprung full faced race disc
    Fidanza flywheel
    Tick performance adjustable master cylinder
    Tick performance speed bleeder
    Full stainless braided hose clutch hydraullics(got rid of all the snap on plastic garbage)
    GMM Race shifter with lous short stick adapter and cobra bobs gasket
    Harrop rear diff brace
    NX large carbon solenoids
    Cometic nox box 2 progressive nitrous controler
    Lingenfelter lnc-002 multi step retard and rev limiter/two step controller
    Meziere electric water pump
    160 t stat
    ngk tr5 or tr6 plugs depending on nitrous use.
    Hurst line lock
    SCSS semi solid trans mount
    Rocksand racing solid billet engine mounts
    Ron Davis aluminum radiator
    Mishimoto silicone hoses
    BDL Billet black anodized radiator hose clamps
    Stefs Fabrication -12 catch can
    Stefs Fabrication -12 breather tank
    Nano 15 lb bottle
    Nano large 4500psi bottle
    Brand x billet bottle adjustable brackets
    Taylor battery box/relocated battery
    Rockford fosgate circuit breaker, distribution block (power and grounds)
    Suspension Modifications: Pedders xa full adjustable coilovers. swapped to 12kg rear 8kg front eibach ERS springs
    Delrin custom machined bushings throughout
    Wheels/Tires Modifications:
    Daily:
    CCW LM-20 18x9/18x11
    Falken Azenis RT 615K
    Awaiting as soon as minitub per Forgeline sponsorship..
    Forgeline GA3R 18x9/18x12.5
    Falken Azenis RT 615K/mickey thompson et street radial
    Race:
    Weld RTS Black
    17x4.5 gto spares/ 15x10
    MH Racemaster 26x4.5x17 front runner/Mickey Thompson ET Street radial 2 275 50 15
    Interior/Exterior Modifications: Interior
    Recaro Pole Position leather/black alcantra seat
    Willans F1 6 point harness with cam lock
    Delrin c5r turned shift knob on lous short stick
    Took all interior out, sanded the silver off the trim, polished the black out for full black interior conversion
    HSV white faced guage faces
    HSV red needles
    Chris white unlocked shift light and cluster reflash with HSV startup screen
    Factory shift light replaced with c4 ultra bright led from streamlite tactical flash light
    Custom machined and wire edm'd steering wheel hub
    Nardi Deep Corn 350mm dished steering wheel
    scss triple pillar custom pod
    scss dual gator dash pod
    Autometer phantom 2 LED 2-1/16: Fuel pressure, Nitrous pressure, EGT, Wideband, Oil pressure gagues.
    Chromolly .083 1-3/4 8 point cage
    gutted rear interior
    Exterior
    Full oem holden conversion
    Commadore vx tail lights
    spoiler delete
    Rear bumper cut out where insert was, rear floorboard plasma cut out and new sheetmetal flat trunk floor stamped out, sealed in, and repainted. (removed 180lbs total)
    Working on functional 14 degree rake rear diffuser and sheetmetal rear wing
    Front splitter with functional turnbuckles to adjust high speed downforce and stability(most of these are plastic and bolt on with screws, total cosmetic enthusiast garbage)
    Pulled 2 inches over stock on front fenders, rears pulled 1-7/8
    RK sport urethane side skirts
    Vauxhall badges
    Front grill delete (clearing some room for an oil cooler)
    Removing front fog lights to build fiberglass ducts to front brake cooling vent adapters.
    enough of my junk, lets see some trucks! Sorry for the multiple ot posts fellers, just didnt want to leave anyone hangin!
  8. #398
    Jun 2009
    Washington DC
    Man, when you start typing, it's f'n epic. You don't have much to say, huh?
  9. #399
    Quote Originally Posted by BLACKLIST View Post
    Im getting ready to sawzall them off instead of taking the time to remove them, lol.. And swap to 1-7/8-2" stepup kooks for my blower setup!
    Fixed it for ya!
  10. #400
    Aug 2011
    Texas,Silsbee
    I love it
    play,work,daily driver it does it all
    5.3 n/p tune 93
    long tube
    off road y
    e-cut out
    e-fans
    hot cam
    harden 7.425
    vettt springs
    servo
    5 pinion carrier
    kevlar band
    Tb stall
    3.73
    G80
    hellwig sway
    eibach springs -1
    eibach shocks
    hd grill-cut
    park wired into DRL
