Originally Posted by
country_3030
You can still use your entire intake setup on the 6.0. Just check to make sure the 5.3 injectors are not a lower flow than the 6.0 injectors. If so I would swap the injectors and use your current intake. Someone else will have to chime in on the drive shaft and x-member part of the question.
so would that hold true for any 6.0 from 00-06?
i knew the intake would work, but you are just saying i should be able to swap the fuel rails with it, and i wouldn't have to worry about return or returnless on the new motor?
i guess i could assume that since i'm using the same intake, i could just as well use my 5.3 throttle body, and wouldn't have any problems keeping the drive by cable set up?
2000 ECSB 5.3L with K&N CAI, true duals with flowmaster 40s, and 200k miles!
