1. The AC compressor is the stock 93 one. The bracket kit is from Josh Powers. Do a little searching for his name and there are several threads with it on here and few other sites. So far I like the setup but I havent got to run it much at all.
2. The intake is for a 6.0L Hummer H2. I did some digging and test fitting and found this one works great for these LS engines in and OBS truck. I havent seen anyone else using one so maybe it'll catch on. haha I did not want some rigged looking PVC pipe or even the alum tubing on this one.
3. The radiator came from a late 90's 3/4 ton Chevy truck. Its a 34" radiator whereas the stock was 31" plus this one is thicker. Its a direct fit to any OBS but will also need the top mounts from the donor truck. I went out and measured my 06 and it had the same size radiator in it so I found some take off E-fans on eBay from an 06 and they fit great. I had to trim the top ears off of them however. My buddy is making me a radiator cover so then I an mount the top. Only the bottom of them is mounted in these pics is why is sticks a little away from the radiator.
Thanks. I will do some more pics and vids once I get few more things done. Its def came a long ways from where it was at.
Truck looks awesome though, good work man.
