Originally Posted by
ecld_07
I checked the input shaft while the tranny was out. This morning I checked to see if it had cooler flow. I pulled the line am had good psi. So I tried to move the truck. It backed up and forward.... I put it back in reverse and had nothing. After it wouldn't move I checked the cooler line. Had no fluid. It hasn't had fluid flow or moved since. I did flush the cooler lines but not the tranny. I did clean what very little trash was in the pan and do a new filter. That's all though. Should I send the stall back to c-d to see if it did break the first time?
Did you ever figure out what it was? I am having the exact same issue.... was wondering if it was a stuck valve on the VB or...?
'03 GMC Sierra 5.3-MP 112-2.8 Pulley-Stg1 706 heads-216/224 .551-BB Tune-4l80e-FTI 2800-Ceramic Pacesetters-4.10s-Yukon Duragrip-
