Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 44
Thread: 4L80e boom and has no gears
  1. #21
    all's well that end's well. glad your back up again
  2. #22
    San Marcos Texas
    Great you got it fixed!
  3. #23
    I AM surprised the CD broke, not surprised the converter broke after my very simple and correct diagnostic.
  4. #24
    Ponca City
    Well i made it about 20 miles and it acted up again. lost all the gears. i never got on it and i know the verter is a good one. so i got it home and pulled the tranny line....not a drop came out(yes the truck was running). when the tranny was out i pulled the pump and looked it over. no wear or damaged teeth... ideas? Good news is i didnt ruin a $1k stall.haha But now i have an extra 80e stall. And props to Chris. I had talked to him and he was going to fix it for free.
    Slowest in Oklahoma...
  5. #25
    did you replace the pump to case gasket?
  6. #26
    Ponca City
    Yes one on bottom and one on side. New filter and filter gasket on it also
  7. #27
    Wichita Falls, TX
    Man sorry to hear your having hell bro. I still love the truck and want it badly hahaha Don't give up on it
    2003 SIERRA- 5.3 DD
    1985 SWB C10- slow, future plans- shaved, painted, 6.0/4l80e
  8. #28
    Quote Originally Posted by ecld_07 View Post
    well if the pump is good & all the gaskets are good you should be getting psi from the pump unless the bolts holding the flex plate to the converter are broken
  9. #29
    Oct 2008
    THe failure is definitely not making much sense... A converter failure actually made sense at first, but now????? We had a mustang one time where the pressure relief valve stuck open and dumped all the line pressure. I have not built a trans in quite a while, so not sure if this is even possible on the 4L80. Very strange how what ever is wrong fixed itself when you swapped converters. How was the converter clearance?
    Chris
    Visit us on Facebook
    Please fill out my Ask Chris form for converter recommendations.
    http://www.circledspecialties.com
  10. #30
    Ponca City
    Comon man. Bolts to the converter broke?? We arnt 5 years old or using plastic bolts.... The circle d fit perfect. The PI needed a small amout of shimming. I'm kinda thinking like chris, maybe a valve is sticking or pressure is being bleed off by a faulty pressure control unit.. Maybe it setting a week or so freed up whatever was stuck for short period
