Results 1 to 10 of 152
Thread: 93 1500 w/ 5.3L & 5 speed swap
    May 2004
    I may have missed it, but what radiator are you going with?
    I'm doing the same swap in my dad's '90 Silvy, too.
    Dec 2004
    San Antonio, TX Area
    I kept my factory truck radiator.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    May 2004
    Quote Originally Posted by Chevy-Art View Post
    Hm... and you're not having any cooling issues? The truck came w/ a 350, so whatever radiator that is is what we still have. I just figured I needed to upgrade.
    Dec 2004
    No cooling problems at all. My radiator may even be bigger than the f-body one.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Manchester, TN
    Quote Originally Posted by ccreddell View Post
    Youll have to share about the headers. Did you use a kit or what?
    I bought some ceramic coating from Columbiacoatings. Its sprayed thru a paint gun then baked on. Came out pretty decent if I say so. But gotta make sure you follow the directions.
    Once you spray it it air dries like a chalky green, then once baked @ 500* for an hour it turns white. Just take some 0000 steel wool and wipe them down. Can be polished out with buffer for almost chrome but wasnt wasting time doing that.lol
    Quote Originally Posted by DANSBIRD View Post
    I swapped out the stock 31" radiator for one I got at the junk yard. Its a like new 34" that came from a 3/4 ton silverado. Fits directly in the core support and is bigger and thicker than my stock one. I am also using 2006 Silverado electric fans that I still need to wire up.
    I have already trimmed and fit the fans to the radiator. They fit on it perfectly as far as width but the top lip and those mounting tabs needed to be cut off cause the core support is shorter on the OBS than NBS trucks.
    Also thinkin of modifying this Camaro SS engine cover to fit. Its a little short and needs to be lowered down on the engine some. If not I'll use the 3 piece Escalade covers.
    91 Silverado Stepside, LT1, 4L60e, Hotcam, RRs, Headers, 52mm TB, built trans, 20" Coys, 5-7, etc...
    93 Silverado, 5.3L, 5 speed, 5-7, 20"s, GMC grille,molded pan, 454SS fogs, HIDS, etc...
    06 Silverado Crew Cab Z71, LTs, full SLP exhaust, tune, CIA, 6" lift, 35"s, DVD, etc...
    Sep 2010
    Mcdonough, GA
    ok thanks a lot. I guess i got the wrong flywheel from the parts store bc my pressure plate wasnt lining up on the flywheel. is there any specific year i need to get. i just got an 03. my motor is a 05 lq4. thanks in advance
    May 2007
    Medford, OR
    Im fairly sure the SBC clutch wont fit the LSX flywheel, so its probably not the flywheel thats the problem.......
    Manchester, TN
    Snapped a few pics tonight. Still need to tidy up some wiring and stuff and make a radiator cover and mount top of fans.. But its gettin there slowly.
    Here's what I did with the fuse block that came with the harness. I didnt like that it was just exposed so I snagged a block from a 96 truck and gutted it. Mounted it on the fender and mounted my fuse block inside it. That way it looks somewhat factory and it protected from the elements. Also shows where I mounted my PCM
    Also if I cant modify the Camaro SS cover how I want the I'll prob just end up using my 3 piece covers from my green truck. haha
    Sep 2010
    Mcdonough, GA
    yeah i was on the rock last night. lol long day. i took the alignment pins out and it fits!
    Manchester, TN
    Not much more to tell but here's a few pics to hold you over. I have been cleaning up on the inside and stuff lately. I found some billet for cheap so stuck that in there along with cd player and speakers. This weekend I hope to fill it with coolant, trans fluid, and change the oil. May finish up the fan wiring if I have time as well.
    Few pics of how the headers look as well as the oil pan. I may swap pans out if I can find a cheap one so this wont get smashed, but for now its staying.
    interior progress
