Results 1 to 10 of 29
Thread: My first nitrous kit :)
    im running the br7ef's in mine, two steps colder and non-projected. Running full timing on the 100 shot and i have a IAT timing tricker wired up to pull 4 degrees of timing when i run the 150 shot. I cut a 1.64 60' spraying outta the hole with a 3600 stall and bone stock 5.3. And that push button switch is a bad idea my friend, ive seen a couple nitrous backfires because of it. Play it safe for now, but i would save up for a harris speed works microedge.
    Rockwall, TX
    Quote Originally Posted by o2camaross View Post
    How do you do this???
    1989 RCSS 5.3/4L60E swap
    - 224/230 .581.591 112lsa,
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
