hahahahahaha... speed density is when the pcm uses only the volumetric efficiency table to adjust injector pulse width. The VE table is basically a table of numbers that represent the pumping effeciency of the engine. SD uses the IAT, and MAP sensors and engine rpm to reference what value of the VE table to use to adjust fueling. Stock our trucks use a combination of the MAF and the VE table. It uses the VE table at low rpm/low air flow and switches over to the MAF at higher rpm/airflow since the MAF doest get stable readings with low airflow. People run SD to be able to copletely do away with the MAF so they can route the intake without having to worry about it and several other reasons. Some will say SD is better and some say using the MAF is better. I dont really know. I like the MAF myself because it measures actual dynamic airflow and is not a "guesstimation" like the VE table. That is why when you make a change to the airflow to or from the engine (ex. headers, cam, heads, intake etc.) you need to retune the the ve and maf tables in the pcm to decrease/add fuel to compensate for the increased/decreased pumping effeciency/airflow of the engine. Thats just my .02 and understanding of the subject. I might have missed a few things or be wrong on a thing or two but anyone is welcome to correct me
