Results 1 to 10 of 13
Thread: What do I need to do. 90 5.7 to old school 350.
    Jun 2007
    Hey guys. Long time how's everyone? So my newest project is a 90 3/4 ton 4 wd . It has a 5.7 4l80 in it. Well the 5.7 locked up going down the rd and will not even turn over don't have a clue why .any suggestion.? I though spun a bearing, locked up timing chain, or tranny locked up.
    So ultimately I know I'm putting my small block I have in it. What do I need to do for it to run ?if I keep throttle body will it bolt right to the old school 350. ? So I searched quickly and didn't find anything. I'm sure its a relatively eSy swap but do t know what I need to do for it to function properly. Thanks in. Advance.
    Jun 2007
    CmOn guys. This has to be an easy one . Lol.
    Apr 2011
    Dallas, North Carolina
    so your saying the throttle body injected motor that was in the truck locked up on you but you have another 350 laying around. the only thing that is gonna be wired is if the other motor was carborated. if so you will have to switch out the intakes.
    May 2007
    Medford, OR
    And knock sensors.
    Jan 2011
    Mcalester,okla.
    the older style heads have different intake bolt hole angles, but u can slot ur tbi intake holes to make it work, it should b the 4 center bolt holes, 2 on each side,put all sensors and stuff off tbi motor on the older motor, also u have use the older style flywheel, as the tbi style has a wheight on it and wheel throw of the balance of motor, if u use the 88 up flywheel it will beat the babbit outa ur mains and rod bearings,so use oler style, i think thats it
    Apr 2011
    yea i forgot all about intake bolt hole angle but i thought the intake angle was only different if it was a 4 bolt main or a 2 bolt main
    Apr 2011
    oh yea and what year is the old school 350 you have laying around that will be the main factor in everything
    Dec 2004
    San Antonio, TX Area
    Quote Originally Posted by Ramsey View Post
    What year did the 4l80 start?
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Apr 2010
    Swap the heads and intake. You will pick up the benefit of the vortec style heads on the older block.
    Jan 2011
    Bismarck, ND
    SGP93GSX the vortec heads didn't come out until 96 so there really wouldn't be any benefit to swappin the heads over the 90 model heads weren't that great.
