Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 40
Thread: Low end sucks!!!!
  1. #21
    Quote Originally Posted by Prank111 View Post
    Yea. Uhh daily driver!!!
    What is that supposed to mean?
  2. #22
    hot & windy
    if you're doing big tires, gearing down your diffs will make it better as a DD because it'll be getting you closer to the stock final drive ratio, which is where that 4.8 will enjoy its life much better. it'll also save you a bit of gas around town.
    99 Sierra - 5.3 / 5spd
  3. #23
    Apr 2010
    Hell Paso Texaz
    YEa i originally post this up to help me out with my daily driver, all yall do is rag on the 4.8 and are suggesting to make a mean rock crawler, drag strip beast.
    03 Chev Z71 4.8. Need quite a bit to go. NPT BABY!!!
  4. #24
    Cus the 4.8 with a 4x4 is weak as it is then you add the tires and crap with it and then its really weak, and so what if its a dd most the trucks on here are DDs
  5. #25
    Put a tornado in and a Fitch fuel catalyst. You'll get plenty of low end power due to the Tornado's tornado-ing effect acting much like a supercharger.
    Because we know what we're talking about. You aren't going to get what you want out of a 4.8 in a 4x4. The end.
  7. #27
    I like how anything with gears or higher stall is automatically a rock crawler and drag strip beast. It's called "every action has an equal or opposite reaction". Automotive 101. Taller tires will make the vehicle act as though it has a higher (numerically lower) gear ratio in it. To correct this, one must install lower (numerically higher) gears. Or live with it. The 4.8 is a high revving motor, why that design was built for a truck is beyond me, but that's not the point. The sooner you get it into it's powerband the better, or yes it will feel like a dog. Again, gears and a higher stalling torque converter.
    hot & windy
    or smaller tires
  9. #29
    Apr 2010
    Hell Paso Texaz
    ok, then another crappy GM design, screw that! a high revving engine, and a heavy body.... How much can i get for my truck? ECSB, 143K 4.8 two tone, Z71 pkg. AR 20" rims mud terrains. Or would it be better selling off at an public auction?
  10. #30
    Racoon Twp., PA
    GM, Ford, Jeep, Dodge, etc..... Don't matter what it is, bigger tires need GEARS.
    20's aren't helping either.
    2013 CC 5.3
    81 C10 LS1 project
