Results 1 to 10 of 38
Thread: To much boost...
    Pittsburgh, PA
    when using the wastegate on the crossover, try sizing your wastegate spring to a smaller size
    just cause a spring is rated at XX amount of boost doesnt mean its going to make that amount. always size smaller then step up, remember its gotta be good to regulate the boost when only controlling one side of motor
    and playboy....he may have the fastest SSS or ext cab but synergy built it
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    I don't think you caught my sarcasm.
    I didn't either. Dick lol.
    Birmingham, AL
    youre absolutely sure that the vacuum/boost reference lines are routed properly to the gate?? something just doesnt seem right to me...
    01 Silverado
    Jul 2009
    Mid-Michigan
    Is it alright to have the wastegate mounted to a flex coupler off the crossover, or should it be mounted directly to the crossover?
    02 Z71-5.3/4l80e-P.I.2800-TR220-Ported heads-Pacesetter LT-Auburn E-locker-E Fans-42lb. injectors-RWHP 301-RWT 305
    Jul 2009
    Mid-Michigan
    Well i removed spring so wastegate would open right away and still upwards of 15 pounds! does this mean i need a bigger gate than a 38?? How big should i go?
    Pittsburgh, PA
    are you saying with no spring in the gate [which means constantly open] your still over boosting? what is the postion of the gate? the gates exhaust is it routed back into downpipe or vented to atmosphere? if merged into DP is it on a angle or more of a 90*?
    Quote Originally Posted by musky02 View Post
    412 Motorsports
    Birmingham, AL
    could the gate be on backwards??
    01 Silverado
