Originally Posted by
SRT10KLLR
My plan was to use one Garrett GT-76 turbo for my Silverado with a 408 but people said the turbine side was too small and would cause high back pressure so I decided to make it a twin setup instead. I pulled the GT-76 from the Hemi and need to make all new hot side piping along with the cold side.
The engine is a 408 with 9:1 cr and a 224/231 .595/.595 114 cam and I will be using the stock exhaust manifolds. It has AFR 225's and the stock intake manifold with a 78mm TB.
What size piping should I use for the hot and cold sides? 2", 2.5", 4" etc.
What A/R should I go with? Currently one has a .96 and the other is a .81. So I can change one to match the other or change both to .70, 1.15 etc.
What size WG and BOV?
Do you think the turbos are too big for my setup and I should just sell them and buy two smaller ones or one big one instead?
My original goal was to make 600rwhp and work my way up to 800rwhp slowly.
If anyone wants to trade there turbine housing for one of mine let me know.
