Results 1 to 10 of 12
Thread: First Engine Build... What Do You Think?
    Im building a 6.0 for my DD/work pickup. It will have 243 heads, EPS 218/226 cam with 4 degrees advance ground in, and LPP longtubes. I also dropped the coin for a 2600 stall triple disc yank converter for my 4L80E. A converter with a slightly higher stall speed can actually be a benefit when towing.
    Feb 2011
    With a circle D 3k stall you will get all the performance you will desire and with a tranny cooler you will be fine on temps and tow just great.
    Quote Originally Posted by TA63 View Post
    Well I will certainly keep that in mind. If my finances allowed it I'd consider building the tranny too, but this build is coming in just shy of $3400 down to the last quart of oil.
    I hear ya. Quality parts are not cheap. Best of luck with your build. Let us know how everything turns out.
