This case works different than the 149. It does not have a viscous coupler. It works kindof like an open diff.
2002 RCSB Z71, 409 with stock heads, custom spec cam, vic jr intake, t-76 Q-trim front mount, Tim Frost 4l80e trans, eaton posi, and the list goes on.
No. My truck leaves hard on 7psi launch and the front end raises and it dont light them up but will spin a little. thats why i said if your making 500 or less. My truck is making well over that. Im going to 80e also and they dont make a 32 spline input for this case or i would keep it.
You need a 149 and so do I. You have the same one that is stock on my 2003.
Im just gonna go with a NP243 behind my 80.
Way more than i want to spend when i already have a case that will work.
