Results 1 to 10 of 11
Thread: Turbo drain on oil pan
    The Garage
    Like the title says, where is the best place to put a turbo oil drain on the oil pan. I was thinking right above the oil level sensor and as high as a I can mount it on the pan. Thoughts?
    Oct 2007
    Bandera, TX
    On the front of the pan under the balancer. As low as you can on the pan. Thats where mine are. Work well... Hope that helps
    single digit street truck
    for build info
    The Garage
    Quote Originally Posted by TurboMic View Post
    Um, as LOW on the pan as possible? I thought the drain was supposed to be as HIGH on the pan as possible so the turbo's oil pours in to the oil that is already in the pan. I'm confused now
    Oct 2007
    Bandera, TX
    Quote Originally Posted by jetmech View Post
    The front of the pan is the highest flat spot on the pan. If you look at the front you will see what i mean. It is still high on the level of the pan. But you just want it low on that front space so the hose wont rub on the balancer. Hope this clears it up
    for build info
    ^^^ Any pics?
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    The Garage
    Ok, got it. I ended up having the welder put a -12 male bung right above the oil level sensor. That seems to be where a lot of people put it and don't have any problems. Thanks tho
    Oct 2007
    Bandera, TX
    Have to look close at the front of the pan
    for build info
    The Garage
    I see them, thanks. Nice LSX by the way
    Mine is in the front also, in the same exact spot... had some oil drainage problems with it on the side of the pan. It also causes windage on the crank if its too high in the pan.
    -2005 1500 Z71 ECSB 6.0 swap, Cooks Racing 4L80E, NP261HD, Carolina Driveline 5" shaft, CST Tie-Rods, front mount 76mm, Livernois hot pipes, Circle-D 258mm (~3500), Mallory 2-step, 100 Dry shot, 750CC RC Eng. Inj, Nelson Tuned, 4.10's, all through a STOCK 10-bolt
    Jan 2011
    i did one on each side , -10 (dont mind the gen3 and gen4 knock sensors )
    2008 Silverado 3500 LTZ 8"lift 37x20's
    2004 Silverado SS -427 lsx/TT/80e
    First 10 second Silverado SS 10.7@130 Video
