Results 1 to 10 of 60
Thread: My 80e swap has begun
    Dec 2008
    san antonio TX
    im gonna give it shot, my truck weights about half of an avalanche. i think it will hold up for now.
    Quote Originally Posted by lechez71 View Post
    remember, at your power level, it's not about weight or hp, it's about how fast you turn that shaft and it's critical speed.
    Mar 2007
    So acording to your theory, if someone goes from 3.23 gears, 26" tires 1:1 @ 6800rpm, to 5.33 gears and the same tires...everything else remain the same, he will be snapping the driveshaft ??????
    Or is just the longer DS as in AVEs, CC, EC tend do to more flexing at higher rpm?
    Have you made some stats of how many RCSB have this problem, compare to the others?
    One thing is certain, the faster u spin a driveshaft the more prone it is to breaking
    Gears tires overdrive all affect critical speed.
    Some break and some don't.
    if u aint breaking,u aint going fast enough ...
    yo you watching the fights tonight?Silva!
