Quik +1 on what Pavetim said, you want your ltrims slightly negative during cruising and anything not in PE mode, so that when your foot goes wot, ltrims go to zero, then you can nail down the a/f ratio and make commanded = actual.
If they are positive, you can't do that.
Having the ltrims positive just to richen up wot is more work and you won't always have what you're commanding in the end.
Pavetim, I completely understand what you're saying, the only statement that I... Is that you have to scale your MAF table to get ltrims negative and positive as well during non PE cruising. The VE table is mostly used in open loop and cold startup, then you scale the maf after the engine warms up.
There's a little more to it, but maf is used to scale ltrims during operating temps, ve is used for open and cold startup.
