Results 1 to 10 of 18
Thread: Front mount IAT's
    Apr 2010
    my last setup usually seen on average 15* above ambiet when under boost for a full pull. the times when i ran e85 mix i seen the IATs drop below ambiet on a full pull.
    Not that I am doubting your results with E85, but how does the fuel effect the IAT when it is direct injected into the cyl? Intercooler selection would be very important.
    Pittsburgh, PA
    same way as any other alcohol based fuel. If you noticed when running an alcohol based fuel most dont run a IC as its not needed
    Quote Originally Posted by SGP93GSX View Post
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Apr 2010
    Quik,
    I am new to the site and I have read alot of threads where you know your sh*t. With that being said it is only my question. If the fuel is not going through the intake track how does it cool the charge? The cooling effect that alcohol based fuels provide are usually pre intake injected or carbed.
    Trust me I am not arguing, I can see cyl head temps or EGTs lower, But IAT's?
    If you tell me that you have datalogged the fuels back to back, I will take your word for it. I am just struggling to comprehend how.
