Results 1 to 10 of 10
Thread: Rear mount guys, take a look
    The Garage
    not all turbos even need a restrictor. restricting a turbo can harm it just as well as over oiling it. some setups are using -6 as an oil feed with no restrictior but also using -12 as drain.
    Interesting. Not saying you're wrong, but in my experience the oil restrictor has always been needed. I figure that restricting oil flow too much will sieze the turbo while over-oiling it will just push oil past the seals but still allow the turbo to spin. Over-oiling has happened to me a few times How big are the turbos with -6 feed and -12 drain? I'm assuming they're pretty big.
    Pittsburgh, PA
    Quote Originally Posted by jetmech View Post
    it all has to do with how much can escape really. more goes in the more has to escape at similar rate. being rear mount youre already fighting gravity, not mention on how far your oil has to travel to exit the system.
    i supply 65psi at idle on my current setup and last setup saw 55 at idle both pegging the guage at 4000+ rpms.
    but if it works for you then so be it. just make sure your getting enough oil to the turbo or it will the bed early
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    The Garage
    just make sure your getting enough oil to the turbo or it will shit the bed early
    Will do. Thanks for all the input
    With your breather setup did you eliminate the factory pcv system all together (nothing to the intake manifold or before he throttle body) and just run the breathers to the catch can?
    05 Gmc Sierra RCSB 5.3 - Vortech V2 Intercooled, BBK 80mm TB, Edlebrock shorties, Custom built 3" Catback W/Borla XR-1, GM Built HD 4l60e w/ transgo shift kit, power servo and corvette shift pin, Yank 2600 Stall TC, Belltech 2/4 drop, Doetsch Shocks, 3.73 gears w/yukon lsd
    The Garage
    Quote Originally Posted by Boost05 View Post
    Yup, I deleted the factory PCV system and just ran hoses from the valve covers to the breather tank
