Results 1 to 10 of 24
Thread: swapped 4.3 to 6.0 and not getting spark to one cylinder NEED HELP
    Feb 2010
    santa fe, tx
    yeah true i will do that tom and see if that spark plug works.
    Quote Originally Posted by butler145 View Post
    it's work to do, but run a new wire from the coil pack to the pcm, there could be an open in the circuit, due to a bad terminal or corrosion on the terminal when it's plugged in.
    we've seen the actual terminals not make contact and not fire the injector or coil.
    Feb 2010
    santa fe, tx
    could the piece on the crankshaft that tells the computer when to send spark have broken a gear off that would keep that cylinder from getting spark at that one point?
    but just that one cylinder isnt getting fire even after swapping a whole other wiring harness. and where harness connects to coil packs have tried 3 different coil packs. so would think that would eliminate any connection issues.
    hot & windy
    i don't believe the crank position sensor has gears in it. at least it didn't look like it when i was checking mine.
    when i did my swap, none of my coils were firing, but that turned out to be a computer issue
    99 Sierra - 5.3 / 5spd
    swapped plugs yet?
    Feb 2010
    santa fe, tx
    yeah have swapped plugs. thats not problem. we eliminated the omputer issue by swapping 3different computers out. used what came with motor , then an extra a guy had and then took one out of buddys truck thatis running and drives everyday and still no spark.
    but i believe the crank position sensor has like little teeth or cutouts on it. i just wondering if those could break some how. cause have replaced i believe everything else or swapped things out and still get nothing out of it.
    its confusing for sure.
    Feb 2010
    santa fe, tx
    the relucter wheel could something of happened to that to cause t to not get fire o just one cylinder?
