Results 1 to 10 of 19
Thread: awd>>2wd
    Broken Bow, OK
    Denali Sierra or Denali Yukon, what year?
    Feb 2009
    Houston
    2003 Sierra
    Broken Bow, OK
    Quote Originally Posted by gTeran1 View Post
    2003 Sierra
    The 2003 Sierra Denali has a 149 transfer case. The AWD system is completely mechanical and contained within the transfer case. There are no AWD diag codes for this truck.
    Feb 2009
    Houston
    Sweet! Thanks alot man. one more question,whenevr my back wheels loose traction it shuts down the aws and throws a 4x4 code.can i tune out the code? because i figure it now being 2wd its going to loose traction alot more now
    Dec 2004
    San Antonio, TX Area
    Do you have any pics of the truck?
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    It is likely to throw abs codes occasionally. The bcm may be the issue. I would also verify that you have the nvg149 because if you do it should not throw a code when your wheels in the back have traction problems. Chances are speed sensors on the transfer case are the tell tale of "Hey throw the code we lost traction" . . . . Gasguzzler is very familiar with these denalis and you might get more info from denalitrucks.com
    Feb 2009
    Houston
    well,it only throws it when i loose ttraction on the sand or mud. and yes,it is a 149. dang thing is 950 bucks.thats why im going 2wd.
