Results 1 to 10 of 26
Thread: 6.0 swap, getting a ticking noise. please step in
    Jun 2009
    Washington DC
    Quote Originally Posted by RidinLow94 View Post
    What ever the ticking is, its causing false knock. I changed out the plug wires and it still didn't change anything
    I pulled all the belts and it still has the sound, my tensioners are alittle loose so I have to look into new ones though.
    Both, but its most noticeable when its warm
    I think you may be on the right track with replacing those tensioners. Ive heard bad pulleys and tensioners sound like that before, but who knows. At least once you replace them you know you'll be safe on that end. How long was that motor sitting before you got it installed (from truck to truck, not just since youve had it)?
    Quote Originally Posted by Mang213 View Post
    I know its not the tensioners causing it but you are right and they will get replaced. I bought the motor back in march and it was already taken down (heads and acces off). I dont remember how long he said he had it, so i'm not really sure how long its been sitting around. i have a mechanic buddy coming by today to run some checks and then I'll be pulling the cam, oil pump, and timing chain. Unfortunately a stock cam will be going in for now, but its brand new. It was in my brothers surplus motor, he swapped in a TR220 b4 it evenwent in the truck LOL. But I'm putting a double roller and a ported LS6 oil pump on, so i'll be ready for my cam when i get it I just reeeeeeeeeaaaaallly hope this issue I'm having isn't on the bottom end. But it really sounds like its coming from the timing chain and echoing through the motor.
    '00 T/A WS6 M6 - GONE!!!!
    '04 Chevy Silverado ECSB -LQ4/80e swapped, 799 heads, Comp 212/218 114lsa, TSP LS6 oil pump, LS1 e-fans, LPP LT's, ORY, Magnaflow muffler, and a slighty tweaked tune
    Jun 2009
    Washington DC
    Yeah it seems like it's a 'surface' issue as opposed to requiring a tear down. It's always tough to tell what could be wrong when a motor's been sitting for a while. Keep us posted on what you find and good luck
    well, rummaging through the old lifters I found 2 that were chewed up on the roller. I'm not sure which cylinder it came out of though, but with them being that bad the cam has to be as well.
    I'll take some pics and post when i'm done
    Jun 2009
    Washington DC
    Did you fid the metal in the oil?
    It looked a little shimmery when i drained the oil last when i changed the lifters, but it wasn't like overly excessive. I guess I can scratch the stock cam dealio, just sent payment for a 212/218
    weeeeeeeeelll this past Sunday, I found this
    atleast its not a spun rod bearing
    it was an messed up day.
    chipped a thread in the crank, but that got fixed and then this
    broke off a valve cover bolt in the head
    and then this while trying to replace the gasket
