Thread: 4.8 to 5.3 ?
    The Garage
    You're on the right track. You'd just need the 5.3 crank, rods and pistons. 5.3L uses dished pistons where the 4.8L uses flat-tops. I have heard of people using 4.8L pistons to up the compression on a 5.3L but I always wondered what it would do for valve clearance - especially with a higher-lift cam.
    Houston
    Quote Originally Posted by jetmech View Post
    i would be more worried about piston pin placement and not the flat top issue. If the pin is in the same place then id run the 4.8 piston on a 5.3 rod, also crank and rods can be 5.3, 5.7, 6.0 ect...
    Broken Bow, OK
    Doesn't the L33 have the same part number pistons as the 4.8? Pretty sure they do, so the pin would be in the same place.
    Jun 2009
    Washington DC
    L33 uses the 4.8 flattops and has a sligthly higher c/r
    Houston
    see there you go, run the 4.8 piston then, i have a set if anyone needs them
