oh really? c'mon i have read them ten times over, its a blazer not an old full size they dont answer my questions what so ever. i was run out of s10 forum so i dont see why you cant help out some.
I will rephrase, can i just pull the unused sensor plugs all the way out of the harness and out of the pcm? what needs to be changed since i switched over to cable throttle body? do i just re run my dash gauges to the new pcm? I havent found much on ignition do i need to re wire that as well?
