Results 1 to 10 of 50
Thread: painting interior accents?
    Jul 2009
    RGV, TX
    thanks for the info,
    went to NAPA yesterday and with my paint code, they were able to make my onyx black paint in a can... which i think is pretty cool and seperate can of clear.
    The surface of the areas I wanna paint are pretty smooth already, im wondering if a scuff pad will be enough "sanding" to get some primer on them?
    2008 GMC Sierra
    1998 GMC YUkon 4X4
    2007 Kawasaki Vulcan 900 Custom
    May 2006
    Waco TX
    Yes. I would use red scotch brite then adhesion promoter then primmer.
    Jul 2009
    RGV, TX
    Quote Originally Posted by Red03SilSS View Post
    thanks, i figured that would work.... i still need to buy that adhesion promoter and primer.... im thinking, auto zone?
    2008 GMC Sierra
    1998 GMC YUkon 4X4
    May 2006
    Waco TX
    Quote Originally Posted by blackjack325 View Post
    Paint store
    Hill Country, TX
    I did all the wood grain in my wife's vehicle which is same interior as yours. I used steel wool to ruf it up and then used Krylon's Plastic Fusion paint and clear. Seems to be holding up great so far. The chevy onyx black is cool, when I sprayed my harley myself, that is what I had mixed up...Good Luck.
    --2013 CC Z71, Edelbrock charged, cam, long tubes, 4.5" Zone, 285/70/18 KM2s on Gear Big Block, Kenwood system, LineX, Retrax, Katskinz, NFab.
    --2012 Dmax CC Z71, Cognito UCAs, braces, Fox 2.0, LineX, Nfab, Retrax, Ranch Hand Front/Back, Custom Katskinz, Black Gear 18x9 wrapped in 285/70/18 Toyo MT.
    Jul 2009
    RGV, TX
    started sanding yesterday
    put the promoter and started priming/sanding/priming/sanding this afternoon...... i work mornings so daylight isnt very much. right now im concentrating on the a/c vent on the driver side where the light switch is on.
    the plastic around the radio is also sanded down, needs a bit more before i can spray on the adhesion promoter. will be posting up pics when im done with the driver side a/c vent, hopefully by tomorrow night.
    2008 GMC Sierra
    1998 GMC YUkon 4X4
    Jul 2009
    RGV, TX
    Im using the filler primer, then sand it down smooth, then more filler primer. After about 4 sets, when i look closely, looks like theres a bunch of little pores.
    Any help? it feels smooth to the touch. Should I keep spraying primer, and sand it down untill I cant see the pores anymore?
    Im unsure if I should just spray another 2 coats of promoter and straight to paint, then clear. HELP!!!!
    2008 GMC Sierra
    1998 GMC YUkon 4X4
    Nov 2009
    san antonio tx
    what do the paint code cans cost?
    04 ecsb 5.3- perfectly tuned by Nelson perfomance, Pacesetter longtubes, 100 shot n2o from NX, cold air intake.
    03 rcsb charbroiled (race truck eventually)
    Jul 2009
    RGV, TX
    Quote Originally Posted by will_oh View Post
    paid $45 bucks for a can of matching body onyx black and a can of clear.....
    ill try to start doing some of it this weekend
    2008 GMC Sierra
    1998 GMC YUkon 4X4
