Just got home from offshore and saw my new engine an tranny for the 1st time. And boy it looks intimidating(on a few different levels). The donor car is a 2010 Camaro. Technically, its an L99/6L80(MYC), but after the cam upgrade and Nelson tune, it'll be a true LS3.
I have a question for some of you experienced guys. The PCM has two plugs that attach to it. But there are two more plugs(shown in the first picture) coming off the engine harness. I assume those went to the fuse/power block under the hood. My question is, will i need that fuse/power block from the donor car? It's going into an 81 short bed.
I'm used to working on older engines without all this electronic stuff, so this will be fun yet challenging. I appreciate ALL the help I can get from you guys.
but it's slowly turning into just plain ole in over my head. Like the pull strap on the hoist! that's some of that good ole southern ingenuity hard at work. I'll have to get pics of my work area up for you to see. Glad to hear that Current Perf is able to help out w/that. Good luck and keep us posted
