Go to Oreillys or Parts house and get fuel injected hose. Take a razor blade and carefully cut the plastic line off the factory fittings. Push the Fuel injection hose on to the factory fittings and there you go. No clamp needed
when you say cut the plastic line off of the fittings, do you just mean the quick disconnect part, or the actual plastic fuel line. i didnt look at everything close enough when i had the bed off. no clamp sounds scarrywill it hurt anything if i do throw a clamp or 2 on there?
