Ive always heard that ls motors love 13.1 far in pe mode. Is that not right?
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
It's a stock tune other than a few Dtc's disabled and tm removed. I want to get a wideband before I start tuning it
Got my wideband in today.... idle/ cruising I'm around 13.6-13.8 at wot, 11.9-12.3
thoughts?
cruising looks fine, as long as cruising a/f ratio is between 13.5 and 15.0 it's ok, it's hard to get an exact on cruising because it's going to be up and down constantly.
wot is a tad rich, we'll need to lean it out a little.
Nelson Performance
NP on Facebook
Youtube Channel
If he's getting good number of cell counts it will average it out and 13.5 is rich at cruise, you only really need richer afr when in PE mode. You can safely go to 15 at a cruise then when you hit PE mode use 13.1, and 12.7 at WOT. Best bet is to tune using your stock O2 sensors and then you will need a Wide band to tune your PE/WOT. You want your LTFT's in the -5 to 0 range, if your in the + that means your lean and it will carry over the correction into PE so will throw off your tune. But tuning using LTFT is actually pretty easy, and pretty accurate using stock Narrowbands.
id rather have a +1 or + 2 then having a rich condition of -3
in cruise mode timing should be high 40s to low 50s with no load, slight load timing decreases but should still be high 30s to low 40s
keep working at it till the MAF is next to zero for error and fuel trims are around 0 thru +3
this is where your mpg will come around at. not enough timing will also increase EGTs!!!!!!!!!!!
2014 Xsport- 3.5 Eco boost
412 Motorsports
