Results 1 to 7 of 7
Thread: want to swap my kit over
    Plainfield, IL
    I believe the 'plates' work better for shots under 200 or so. After that, I would imagine a nozzle setup is the way to go. Under a 200, just not worth the cost IMO. Is your kit wet or dry? You will need tune changed
    Yep just likely need a different plate, and your fuel jet will change cuz I imagine the sniper kit is set-up for the 7-8 psi a carb motor needs.
    Okeechobee, Fl
    Quote Originally Posted by sleeper1500 View Post
    +1 exactly what devon said, plate not nozzle, plate is way better!!!!
    49 Ford F1
    Birmingham, AL
    other way around there boss.... the plate is supposed to attomize and distribute the nitrous and fuel better
    01 Silverado
    I think a direct port nozzle setup is what he meant for over 200
    Nov 2009
    san antonio tx
    ok so i just droped off my solenoids and some switches at nelson's, and gona see what allen comes up with.
    04 ecsb 5.3- perfectly tuned by Nelson perfomance, Pacesetter longtubes, 100 shot n2o from NX, cold air intake.
    03 rcsb charbroiled (race truck eventually)
