Have you wieghed your truck?
chevyboy.520
06 ecsb 5.3, FAST LsxRT 102, FTI cam! LT's, tru dual, magnaflow, 3400 stall, Performabuilt lvl2, 4.10s!
PRC stg 2.5 5.3 heads Awaiting to go on!
This should help if you're gonna relocate the IAT
http://kb.ls1gto.com/KB/article.aspx?id=10279
What was the DA when you ran that time? A good night could change everything for you. A friend of mine has a TA that has run a best of 11.69 and on a hot day he's lucky to break mid 12's. My cousin build a beast of a forged 404 stroker and has only ran a best of 11.28 @ 119 in this heat. The car has mid 10's in it for sure. He spared no expense with TEA ported TFS 225 heads, custom EPS cam, Fast 102/102, 1 7/8 LTs plus suspension mods and should be putting out over 500 rwhp easily.
But like everyone said, get some stock wheels, take off your tailgate and spare and your backseat if you have to. Figure about .1 for every 100lbs you drop.
2005 Silverado SS AWD
AEM CAI, ARH LTs, HD-2 shift kit with vette servo, Circle D 278mm 3200 stall Madtunesracing.com street tune (MTR now has a Dynojet 248 chassis dyno)
13.82 @ 94.92 w/1.83 60'
I'm curious to what your truck puts down with that cam, and then with thT 150 shot! Have you dyno'd yet?
chevyboy.520
49 Ford F1
I dyno'd mine in Phoenix and it was hotter then hell, I put down 355rwhp and 350rwtq after 6 hot runs. My tuner was messing with timing and since it was so hot he said that I'd put down about 15 more hp if it cooled down. I was impressed and happy with the results. I could feel a difference on the street, had a little more get up in it. I need to get my nitrous kit on, cuz I want to hit 12's as well
chevyboy.520
Get the .3 yet?
Well chevyboy I hope to put down 400+ since most camed with header trucks put around 300..
And Devon na man I have been so stinkin busy I havent had a chance to hit the track. I actually just got a plate for my kit idk if that will help times at all I just know people always prefer them over nozzles and i got a really good deal on mine( thanks randomhero).
49 Ford F1
plate kit will hit HARD! Trust me. Stock front wheels with smaller thinner tires works well, I picked up a tenth with stock fronts over my 20's. UDP will pick up a tenth or so, and works well with Cams and nitrous in the higher RPM band.
06' rcsb silverado H/C/I/N2O 5.3
49 Ford F1
