Results 1 to 10 of 15
Thread: It lives!!!
    Apr 2010
    South Texas
    looks cool dude; guages look awesome did you put them cause you wanted those or you couldnt make the originals work? Is the a/c bracket easy to install; I have mine there just havent made the time to put it on..
    Quote Originally Posted by slightly_modified View Post
    Original guages would have worked fine, with correct sensors. But I wanted something different. As for the bracket?? I had to remove a small area to clear one of the bosses on the water pump. It's seen in one of the pics I posted in the My Garage section.
    1993 C1500, Indy 500 Edition - 6.0/4L80, complete Hotchkis suspension upgrade, '98 GMC front end swap, 17" AR Torq Thrust II's.
