Thread: Fuel injectors and pump info....
    Feb 2010
    Corpus Christi, TX
    Alright well almost done gathering all the parts to do my turbo but lack a few things like my injectors. Does anyone know what replacement injectors i can use in my 2009 5.3 flex fuel. Looking for at least 42lb injectors or bigger cuz i plan on installing a forged 370 or 408 later on. Also continuing on the fuel system will my factory fuel pump be alright to support 6-8 lbs for now? Im planning on installing a walbro fuel pump later but need some info on that too like which one to use cuz idk if they make one that directly replaces mine. Thanks
    2011 GMC Sierra 4x4 427 LSX 6-Speed
    Feb 2010
    washington
    ive got a 5.3 with 42 pounders and a single walbro pump and at 7 pounds the pump is maxxxxxxxed out and the injectors or at 95% duty cycle.
    Feb 2010
    Corpus Christi, TX
    damn so 2 255 pumps and some 60lb injectors should be enough then? I dont plan on maxing out my 5.3 or 408 boost wise maybe 8 max for my 5.3 and 15lbs boost at the most with the 408....
    Feb 2010
    washington
    Quote Originally Posted by Three6GMC View Post
    With dual pumps and 60's u should be fine with the 5.3. With the biger motor and more boost u might be running close on the injectors.
    The Garage
    Quote Originally Posted by ss6speed View Post
    +1
    With 2 Walbro 255's and 60#ers you'll be fine up to about 12psi on the 5.3L. As for the 408, I'm with him ^
    Feb 2010
    Corpus Christi, TX
    alright cool thanks it looks like ill just get dual pumps in there some how route them and im good should be pretty easy......one last question im looking at some injectors im gessing my injectors have the USCAR connectors by looking at them and comparing them to others...my question is can use the same injectors that are for the 2010 camaros l76,l92,ls3? Im looking at the ones TSP offers these ones specificly
    Name:
    F.A.S.T. 65 lb. Fuel Injectors, For L76, L92, LS7
    Item#:
    111-30657-8
    Price/ea.
    $419.99
    FAST™ Precision-Flow™ Fuel Injectors for GM Gen IV engines are the highest flowing injectors available and are uniquely designed for direct installation into LS2 and LS7/L76/L92- style engines. Available in two different height configurations and a wide range of flow rates, the new Precision-Flow™ Fuel Injectors are correctly sized (shorter than the common LS1/LS6 injectors) and feature the correct USCAR connector, enabling hassle-free plug-in operation. In addition, the high-impedance, high-flow FAST™ injectors meet/exceed all factory durability standards and quality tolerances.
    Prior to the arrival of Precision-Flow™ Fuel Injectors for GM Gen IV engines, performance engine builders were required to retro-fit high-flow Gen III (LS1/LS6) injectors which required a wiring harness adapter to fire the injectors. Most importantly, due to the fact that LS2 and LS7 engines feature shorter fuel injectors than other LS engines, when performance injectors were required engine builders would have to modify the fuel rail placement to fit the Gen III (LS1/LS6) style injectors. The new FAST™ Precision-Flow™ Injectors for GM Gen IV engines are simple drop-in components offered in fuel rates up to 57 lb/hr* (LS2–type) & 65 lb/hr* (LS7/L76/L92-type), the highest rate currently available for GM Gen IV engines.
