Results 1 to 2 of 2
Thread: 2010 projects starting...
    ok so i picked up a set of 243s with 11k miles on em and manley springs good to .600 lift
    so..
    what i need help with is..
    1) what pushrods to get
    2) what cam to get, and help in understanding the specs of a cam to make a good decision
    3) should i get the LS2 double timing chain
    4) i want to find some valve covers to get them powdercoated or polished
    5) i want to find a timing chain cover so i cant get it powdercoated.
    ok ya'lls turn. GO
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
    Quote Originally Posted by MidwestSS View Post
    so..
    ok ya'lls turn. GO
    1. push rods are gonna be determinded on how much you mill the heads, if you dont mill them or even slightly mill them 7.4s would be fine
    2.i would talk to patirck g about specking a cam out for the intire setup
    3.single works just fine, i am still running on the stock timing chain
    4.any 4.8.5.3 or 6.0 valve covers would work
    5.same as above
    on a side note i would go with some 600+ double springs so you dont limit the cam
