Results 1 to 8 of 8
Thread: Quick fix!
    Sep 2009
    Is there a fix for 4 wheel drive?
    My '02 Tahoe is between 3/4" to 1" higher on one side. Nobody else notices, but I do! I thought it looked off when I was detailing it, so I measured to the top of each wheel well, and sure as hell, it was off. My truck has the Autoride suspension and the rubber boots on the rear shocks were cracked so I replaced them. I got them from Arnott Ind. for half what the dealer wanted. I also replaced the compressor, but neither of these repairs took care of the droop on the one side. Any ideas? Thanks!
    Wichita Falls, TX
    theres a spacer sold by belltech that sits on top of the driverside coil that will level it out.
    2003 SIERRA- 5.3 DD
    1985 SWB C10- slow, future plans- shaved, painted, 6.0/4l80e
    Sep 2009
    Thanks!
    I'll check out their website. You wouldn't know what it's called would you?
    Wichita Falls, TX
    no you might be able to google it
    2003 SIERRA- 5.3 DD
    Jan 2007
    Quote Originally Posted by bruceb3 View Post
    Quote Originally Posted by lowchevytrucks8503 View Post
    That would work except Tahoes do not have coils in the front. I suppose a spacer in the rear coils would work but since its a torsion bar front end just crank the bolts on the torsion bar keys until its level (up or down depending on preference).
    Just a 4.8.......
