Results 1 to 10 of 16
Thread: main pully problems "front seal"
    Mar 2010
    Paris, TX
    Seen something similar on a Toyota after customer had timing belt done at another shop. Balancer twisted the key way and jammed up against the bolt head. I would definitely take it apart to check the balancer and crank snout. Also I always use a little blue loctite when I torque a crank bolt.
    Edit: Disregard This Since There Is No Key Way
    99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=7887&dateline=1270435  715
    Feb 2009
    Quote Originally Posted by country_3030 View Post
    the inside of the crank is all balanced and there is no key way...
