Day 2 and the LT1 is sittin' pretty, well it's sittin', in the truck.
Just a little background on this project. This is a semi-daily driver and I'm working with a very short time frame here. So, cleanliness has taken a backseat to functionality and time constraints. I mention this because normally I would have cleaned up the engine compartment and parts much better if I had more time. It will be cleaned up once all is operational. Anyhow...
The old TBI has hit the ground and been rolled out the door.
I replaced the factory fuel sender, cause it hasn't worked since I bought the truck and installed a new 45 psi in-tank fuel pump.
I used the original motor mounts and the motor slid right in as though it was meant for the truck.
The flywheel cover did have to be trimmed slightly around the starter because the original had a different offset apparently. Nothing a sharp blade and power tools couldn't take care of.
The A/C delete bracket came very close to the sub-frame support but it cleared.
Installed the drivers side header and then realized I needed to weld an O2 bung (great word btw) onto the passenger side header collector, which will be done in the morn.
The 4x4 has an oil filter adapter that mounts the filter sideways to clear the front drive shaft and has oil cooler lines that went to the original radiator. I omitted this and went with a shorty filter since the T/A radiator doesn't have an oil cooler. I don't do a lot of towing and don't think this will cause an issue with oil temp, but I'm contemplating adding an external cooler later.
The wiring fun starts tomorrow and hopefully will go smooth enough thanks to alldata wiring diagrams. Radiator mounts, mounting the P/S reservoir, and ECM are also on the list for tomorrow. Full day planned, thank goodness for energy drinks and good weather.
I'm going to post a link to the pics on my Facebook, let me know if it doesn't work and I will post here instead. Ian Robinson's Photos - LT1 Swap Pics | Facebook
