Results 1 to 9 of 9
Thread: convert 4.8 to 5.3
    Feb 2010
    convert 4.8 to 5.3
    I have a 4.8 shortblock gen IV
    I've seen the 5.3 and if im not mistaken they share the same bore - the difference is the stroke.
    in order 2 convert it to 5.3 would i only need to change 2 shorter rod and longer crank.?
    hot & windy
    i know the gen3 5.3 motors also had dished pistons, except the VHOs - they had the same flat-tops as the 4.8
    99 Sierra - 5.3 / 5spd
    Feb 2010
    gen IV 4.8's/5.3 share the same flat top pistons..
    why not just get a 6.0
    Evant,tx
    all u need is the 5.3 crank with the right reluctor wheel for your aplication and the 5.3 rods
    Pittsburgh, PA
    Quote Originally Posted by zebra View Post
    where did you get that info at? you might want to look into that a little more
    to the OP your better off just finding another motor instead of going thru that hassle
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Little mixed up, the HO 5.3's had the flat tops and were aluminium. The VHO's are the same a 2wd SS
    hot & windy
    where did you get that info at? you might want to look into that a little...
    Quote Originally Posted by sleeper1500 View Post
    my bad... i was talking about the aluminum 5.3 with the 243 or 799 heads - whichever truck that came in
    Tyler, TX
    to answer the question, yes a crank and rods would bring you to a 5.3L displacement, but if you bored the 4.8L out to 3.905'' and kep the stroke, you could build a high revving 327, which would be great with heads and a cam that had a high rpm range powerband
    www.tjc.edu
