Results 1 to 10 of 630
Thread: Gears, Posi's, Lockers, Bearings, Axles, More!
    Sep 2009
    MI
    Quote Originally Posted by keniff View Post
    sweet.
    any idea how much more GM gears would cost me? or maybe i should go Motive gears 4:30s lol
    Hello, the AAM gears are $199.99, but not available in the 4.30 ratio. The 4.30 Motives are also on backorder. We have Yukon and USA Standard 4.30's available.
    Thanks!
    Dec 2009
    Houston, TX
    Quote Originally Posted by RONS MACHINING SERVICE View Post
    Thanks!
    Ron - with AAM not being available in 4.30, what would be your top recommendation out of Motive, Yukon, and USA Standard for a 4.30?
    Also, what are your views about gear break-in periods?
    Thanks!
    2006 Z71 Tahoe - Silver Birch Metallic
    GO: Wheatley 93 street tune, TR220-112 cam, PAC 1218 springs, Comp rocker trunions, U/D pulley, LS2 timing chain, JBA headers, cat delete, Magnaflow catback, AEM CAI, 180º stat, ported TB, Circle D 3200, TransGo HD2, billet servos, Tru-Cool 40K, LS6 valley cover, and many more...
    SHOW: Ford keys, 2" spacers, Bilstein 5100, SS cluster, HIDs, LEDs, and many more...
    Quote Originally Posted by Z'06 View Post
    Thanks!
    just to let ya know i went with USA_S gears so far so good, i have beat on them for the last few weeks and theyre holding up great!!
    Simple: 408 on steroids!
    single digits coming soon!
    Sep 2009
    MI
    Thanks!
    Hi, well, all three gears are made of the same 8620 steel, so strength will be the same. For the most part the Yukon's are the quietest running gears besides AAM. The break-in procedure is very important. The main thing is not to build to much heat into the gears. The first 500 miles should consist of short trips with a cool down period every 15-25 miles. You should not tow anything for the first 500 miles. The oil should also be changed after the 500 mile break-in period.
    Thanks, Ron
