Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: 4l80e in OBS
    Nov 2009
    Fort Smith, Arkansas
    BTW I forgot to mention this whole time that this is going behind a 5.3.......oops
    Nov 2009
    Well I got a sweet deal on a 4l80e so I guess I'm goin that route. I found a guy with a mild-mileage 80e that needed a 700r4 and he agreed to trade straight across! Go figure. Anyway, I found this converter and need to know what you guys think....GM 4L80E 9.5" 2800-3600 STALL TORQUE CONVERTER 4L80-E:eBay Motors (item 250549646150 end time Jan-15-10 10:05:08 PST)
    I heard that going to a 9.5" converter on a 80e makes a big difference in parasitic losses and the stall on this converter will better compliment my cam. Comments welcome.
    Also I still need to know if I need a 6.0 flexplate and spacer to run a 4l80e behind a 5.3
    thanks
    Augusta, Ks
    You will need a spacer and 6 hole flywheel.
    The converter looks decent but the cheapest isnt always the best. I know a similar circle D verter is about $795
    2004 Buell XB12s
    Nov 2009
    $795?! Holy piss! I know you have to pay to play but damn. This one has a one year warranty. Ill probably go with it unless someone has a good reason for me not to.
    Augusta, Ks
    Yeah its expensive but 80e converters usually are more expensive. Ill be getting one when I go my swap. They are billet is why they are pricy.
    2004 Buell XB12s
    Nov 2009
    @%$#!! Today I drove three hours one way to pick up what I was told was an 02 4l80e. After getting it home to look at it and doing a little research, I found out its a '96 model! Does this change anything major? I know they were changed a little throughout the years - I think 97 or 99 but I dont know if it changes if I can use it or not. Please advise!
    I knew I should have done my research BEFOREhand so I would know what I was lookin at when I got there. Then, I could have identified it right there.
    are both cooler lines next to each other or is one near the rear of the trans and the other up front?
    Nov 2009
    the cooler lines are close together near the front....
    Monett Mo
    Im running a 96 model behind my lq4 so far I havent had any issues.
    1992 rcsb k1500 lq4 4l80 swap done.If anyone has questions feel free email as I'm not on here very often. bobby_seitz@yahoo.com
    Nov 2009
    Quote Originally Posted by 92 6.0 View Post
    Thanks for the confirmation! Did your cooler lines install with no modification? Any issues with the gear linkage?
