Results 1 to 9 of 9
Thread: Changed my mind need info
    Feb 2009
    baytown, tx
    Quote Originally Posted by keniff View Post
    5.3/60 combo w harness can go for about 1400-1800 depending mileage an what else is included. or do a 4.8/60..its up to you.
    what yr truck is it going in? 99+ you will have it easy as hell
    anyways good luck with it man..its not a cheap process
    Hey what's up this is going in a 96 rcsb the truck is a 4.3 5speed. I've got alot for a 5.7 vortec block, heads, scat 6" rod, SRP forged pistons, roller rockers, iam also looking at the muther thumper cam kit..
    Oct 2003
    Quote Originally Posted by stroker52 View Post
    So, you going with a 5.7(350) Vortec, or an LS engine? They are different. LS1 is a 5.7...sort of. Its actually 346 cubic inch. Then you have the 4.8, 5.3, 6.0 & 6.2 LS series engines...etc.
