Results 1 to 10 of 30
Thread: Engine mount selection
    Dec 2009
    Thomasville, ga
    Engine mount selection i want to run my 700r4 in the stock location
    What company (if there is one) makes a mount setup that will put the ls motor in the exact location of my current engine. i found 20 different companies that make them but through research they all move the engine forward. I am going to run my 700r4 and do not want to have to move it. And i dont want to have to go through the hassle of tryig to modify some to make them work. if i have to i will but would rather not.
    Dec 2009
    Thomasville, ga
    And could someone tell me how im suposed to use THIS. does it make it where i can use my 700's flexplate and converter or does it make it where i use the ls flexplate and 700's convertor. just trying to get all of my ducks in a row.
    1984 c10-its an old truck with an LSX
    Dec 2004
    San Antonio, TX Area
    Is the engine going in your 84 or something else? When I installed mine in my 90 I used the original location of the 700r4. And it sat in there with no modification to the plates.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Dec 2004
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Dec 2009
    Thomasville, ga
    Quote Originally Posted by Chevy-Art View Post
    yes its going in my 84. and the reason i want clarification is ive read where some mounts move the engine forward.
    Dec 2004
    He did it, you may try a PM. http://www.ls1truck.com/forums/lsx-t...silverado.html
    I know there is a couple more that have done on the 73-87 trucks. They may chime in.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Dec 2009
    Thomasville, ga
    i talked to him over on pt.net and he moved his engine and trans way forward. i think it was close to 4 inches. thank you for helping me look though.
    Dec 2004
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Dec 2009
    Thomasville, ga
    I found that one in a search this a.m. he used a 4l60 and modified his crossmember though. finding someone who used a 700r4 in the exact same location as it was installed from the factory is gonna be harder than i thought.
    Dec 2004
    If you bolt the 700r4 to the Gen III engine and then install it, it should work. Just use the 84's cross member as a guide. Bolt the trans to the cross member and the cross member to the truck frame. For this you will need the adapter plates installed.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
