yeah its a z71 but when i swap trannys im going with a 2wd, i never use 4wd anyway....now i need to find a 2pc for it
00 silverado
www.quickstreettrucks.com
instead of buying a weak stock 2 piece it will be better to have a nicer one made, mine was $320 with thick walled steel and solid u-joints...well worth it. Also going from a 1 piece over to a 2 piece you will need to weld in a carrier bearing support...the frame is already there for you to weld to...it's right around 45'' from the rear u-joint cup to the center of where the support willl be
