Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: FLT L5 Billet DEAD?
  1. #11
    Quote Originally Posted by 2boostedSilverado View Post
    Red,
    just for asurance, P0102 must be turn off too?
    Leave those codes alone, lol, they are set ok, your truck is sd tuned.
    101, 102 and 103 should be set to 2, no MIL light and have a checkmark in the box.
  2. #12
    Mar 2007
    Quote Originally Posted by Vince @ FLT View Post
    Not sure who you have to do your tuning but these are the codes that are normally turned off with a high stall converter. PO751 and PO757. The issue is because the computer see's slippage due to the converter stall being higher than what the factory spec's are. Sounds like your trans went into a limp mode condition (3rd gear starts) which really is not the transmissions fault. It is only doing what the computer is telling it to do.
    I think the title of this thread should read I have a code on my FLT Billet transmission! Need help! Vince
    Hi Vince,
    I actually co-op in the tunning, and sure my tuner
    probably forgot this. You and Red are totally right, the trans went to
    a 3rd mode and I had to manually shift it to my home. Now I know what
    to do, since this happend I have not touch the truck cause I did not
    want to mess things up. That is why I post this, cause I know nothing
    about transmision behavior, and to my untrained eye, it was in fault
    and totally dead. Before that it has work like a charm. Hopefully this
    weekend I'll flash the pcm and get the trans back on line. And btw, if
    the trans was-is damage, I was-will go for a FLT L7. I really like ur
    service, and both of my FLT trans for my non daily drivers have
    delivered great. We all know 4L60E r the weakest link of our 5000
    pounds rigs. But I'm kind hard headed when it comes to 4L80E (hate
    them), and changing my Auto trans supplier (FLT). Gabe
  3. #13
    Mar 2007
    Too Late Dude...did as Red Told me and probably now is a high 10's truck..LOL
    JK, just checked the tune file, and it was as RED told me, no need to change anything there. Thanks Anyway
