You could put this one in for that price. I think. Remember it is a 4wd trans and you will need to change the input gear in your transfer case to match the trans. Time2kill on silveradoss.com sells the necessary gear. You would also need the front driveshaft out of a 2500 he might have that as well.
Yes you will need a custom front driveshaft. I am not sure of the rear driveshaft and the input gear can still be obtained from time2kill. I have not done this swap yet but it is in my near future or I would tell you what exactly to do about the shafts front and rear. Kbracing will cut and weld your crossmember for 40 bucks or so plus shipping if memory serves. Thats about all the info I have.
Oh wait, Front shaft needs to be smaller diamator and is a different length. An SS is if I remember right a shorter shaft. Don't know if a regular front shaft would work. I doubt it but I plan to try it and see once I get the cheese for a built 4l80.
A 4x4 60 to 80 swap is more involved as the tranny/transercase is moved back about 1 11/16. A stock front drive shaft from a 2500/3500 truck (you must tell them its for a 5speed trans to get the right one from a junk yard) will fit and you have to shorten the rear shaft 1 11/16, as well as cutting the cross-member and moving it back. Also, as stated the input gear on the transfer case must be changes out the the 4l80 gear on the autotrack and a special made one for the AWD tranfercases. It also uses a different adapter between the tranny and transercase then the 60 does. It is much more involved then 2wd swaps.
PS, Would be nice to have this tranny for a spare,You should hold it for me until the LS1truck track day in case history repeats its self,
01 ECSB 1/2 ton 4x4 6L GMC
11.03@127
KB Racing Borg Warner S475 turbocharged
