Results 1 to 10 of 52
Thread: what valve springs u guys running?
    Lancaster PA
    I read somewhere that the pushrods are the weakest link in the valvetrain, 120 for hardend is cheap insurance in my eyes.
    04 GMC Regency - Building a 6.0 Comp 7.4" Hi-Tech Pushrods, Patriot Performance 8401 Spring Kit, Comp Double Roller Timing Chain, ARP Rod Bolts, ARP Head Bolts, Cam - I dont know yet, any suggestions???
    89 Chevy Cheyenne - 10/24/09 Time of death declaired at 8:16pm.
    The Garage
    Quote Originally Posted by Mang213 View Post
    Is it a good idea to go to hardened pushrods at this point, with the heavier spring, or do stockers handle the rate change?
    Quote Originally Posted by Sargen View Post
    ABSOLUTLY YES! If you are going to upgrade valve springs, it is a VERY good idea to install hardened pushrods. It is cheap insurance and they are the weakest link in valve train. Not only that, when you are in the process of replacing vavle springs, the pushrods are fully exposed. All you have to do is pull the old rod out and drop the new one in - takes about 34.7 seconds for all eight once the rocker arms are off.
    Jun 2009
    Washington DC
    Quote Originally Posted by jetmech View Post
    Hmm, you must be slow. Ive heard of all eight rods being swapped in only 32.6 secs. You need to practice more, bro j/k
    Jun 2009
    Washington DC
    I figured this would be the right time to do it, since youve got the valve covers off. I just didnt know what the real world experience was with the stockers. Ive heard that they were kinda weak, but you know how people find a way to make the oem stuff last with some tricks. I guess these are just so easy to replace that its a no brainer
    The Garage
    Yeah, I wouldn't chance bending a pushrod. My friend just ripped his engine apart and i believe it was the number 3 cylinder that had a pushrod do a contortionist act. It was pretty gnarly, then again he has a FORD. Oh, and I'll work on getting faster - maybe I can get faster than 33.9 seconds
