Results 11 to 20 of 22
Thread: What??...no Heat
  1. #11
    Pittsburgh, PA
    dexcool strikes again. youre heater core is clogged have fun replacing that
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  2. #12
    McConnell AFB, Wichita, KS
    ya thats what i was going to try tomorrow. thanks for the help guys. we'll see what happens tomorrow. gary
    2005 SS AWD, 22" REPLICAS, VOLANT CAI, MAGNAFLOW EXH, 1/2 DROP- NEXT: TUNE, SHIFT KIT, SERVOS, TRU-COOL
    (SOLD)2000 ECSB HARLEY DAVIDSON EDITION. 2''/4" DROP, 20" BUDNIKS, COWL HOOD, MOLDED ROLLPAN, CLEARS, DROP IN K&N, MIT, TAYLOR WIRES, LOUDMASTER EXHAUST
    1991 RCSB S10 355 SBC, 700R4, 8.5" 10-BOLT, 18"/19" C6 Z06 WHEELS, 4"/5" DROP, MAGNAFLOW DUALS W/X-PIPE, FULLY SHAVED W/ CADDY LIGHTS: NEXT-LSX 370/PT88/TH350
  3. #13
    Uh....yeah. Heater core is NOT a fun thing to do. Pretty much have to take your ENTIRE dash off. I would do what Nathan said--try using a water hose to flush first. Try a short, lower pressure back-wash first, then higher pressure normal flush.
  4. #14
    Doubt it's plugged. Not common unless it's a C-car Caddy or and S/T like mine. Dexcool only turns to crap on vehicles with a non-pressured overflow AND propensity for coolant leaks. When Dexcool is subjected to oxygen and heat cycles is turns to sand. Sealed systems like those on the GMT800 and 900 don't expose the coolant to the air and they don't have leaks. The GMT400's have a vented overflow and leak from several areas.
  5. #15
    Aug 2009
    Iowa
    +1. In my 4 years as a GM tech I never replaced a heater core on a C/K truck. 99% were on S/T trucks. Most common problem an C/K's was the tep door actuator. I would definatel look into that 1st. If I remember right it is on the Pass. side on top of the HVAC box.
    Rubie.
    2006 GMC Sierra 1500 HD Crew Cab 4X4, 6.0L, 12" CST lift, 37" tires, CAI. Vinci cam 210*/218* LIFT .587 / .595 LSA 114*4A, Power Slot rotors all around with ceramic pads, Rebuilt 4L80E with shift kit and billet converter.
    Rubie
  6. #16
    thanks for all the help guys. gary
  7. #17
    so i pulled the heater hoses and used the hose to flush the core out like nathan suggested. well im pretty sure it worked. it wouldnt flow the normal direction but i soon as i flushed it through the outlet it pumped out some less than quality looking junk. im sure brown nasty gunk isnt good for the cooling system. what do you guys use to clean out the system before replacing the coolant? beside the actual machine. thanks for all the help guys. its nice to have heat again since its getting cooler outside. gary
  8. #18
    Augusta, Ks
    Napa sells some stuff that Ive had good luck with. Its made by macs or something like that. I can find out for you tommoro
    2004 Buell XB12s
  9. #19
    ya that'd be cool. see how much it is too. thats a long trip for me. hahaha
  10. #20
    Augusta, Ks
    NAPAONLINE®
    Doesnt state price
    2004 Buell XB12s
