I like pacos setup. Autotrac. 4wd at launch then 2wd 2 seconds into the run. You get all the traction and none of the parasitic loss.
OK but how sure are you that it does go back to 2wd at WOT. Mind would not till I let off the gas completely.
Try driving around with more than 500 hp and pull into traffic in 2wd. Tires go quick. Then drive around on auto 4wd and when it kicks in it is rather violent.
Seems you missed the entire point of the swap.
