Results 1 to 5 of 5
Thread: Rebuild cost for 6.0?
    Crossett,Ar
    So I found a decent price on a lq9. Its a core motor. They want 450 for it. Longblock, But it needs to be gone through for piece of mind. Thinking HEY why not do it right. So I search through the net for just a good 6.0 piston or a size up (guess that would be a 370ci then?) and cant find prices. More over I cant find prices for bearing kits, gasket kits etc. How much would it cost to go through a motor? I found a head swap gasket kit alone that was 279. Does that sound right? Has anyone ever had this done to their motors? And how much did it run them? Also being I am going to only run n2o on my motor would it be a good idea to mill the heads down a bit to get higher compression while the motor is apart?
    Nov 2006
    Mesquite, TX
    way to much for the head gaskets...they are about $4x per side and when you buy them get ones for a 08 escalade..when you look for pistons for a 370 look for ones that are .030 over sized from stock 6.0....pistons will run you $600 range...rods will be $500 range...and then might as well do ARP studs and stuff..so all in all you are looking at 3 grand for a built short block
    Racoon Twp., PA
    2013 CC 5.3
    81 C10 LS1 project
    Crossett,Ar
    Quote Originally Posted by tanz45 View Post
    Found that one as well. 6.0 years stopped at 02, Dont know if there was a big difference there though.
    Mar 2007
    Newark, Delaware
    Quote Originally Posted by mean05 View Post
    Why 08 Escalade head gaskets? I'm getting ready to swap my heads, just trying to gather the right parts.
