Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 31 to 40 of 57
Thread: 11's N/a Possible?
  1. #31
    Quote Originally Posted by ecld_07 View Post
    12.6-12.7 my friend
    Crap, You're right. He was 11.34 on nitrous. He ran 12.66, 12.67, and 12.68 at SAR on motor lool.
  2. #32
    Jon could run hi 11's N/A and high 10's on the 175 shot if he would... replace the front 20's for lighter 15"-16" wheels, take out the back seat, take out the 1 of the 2 layers of carpet/insulation inside the cab, take out the 10" speakers/box/amp, and lay off the blizzards lol... seat, carpet, stereo stuff=300lbs. easy! And some good da for the N/A run also
  3. #33
    ff_jeff Guest
    Quote Originally Posted by DBTBSS View Post
    totally true. all he needs is 3 tenths. theoretically, thats either 30whp, or 300lbs. I bet he could hit a 11.8 NA with out touching the motor.
  4. #34
    Round Rock, TX
    Ok next time out to the track I will do all of the above...Plus I will ubolt the hidden reciever hitch in the back too.. Thats good for atleast 50lbs....I really want to do as is though...I'm not trying to be the one that gutted everything to run a certain time...Plus this is a show truck not a drag truck...
  5. #35
    Quote Originally Posted by DBRODS View Post
    Your avatar makes me think otherwise.
  6. #36
    ff_jeff Guest
    We need to find you some front wheels too. You said the offset on the ones I gave you were not right? or did they just need the right tires? Not only will getting you into 11's NA be cool, But if you hit 11's NA, 10's on spray will be that much easier. You better call me when you plan on this, I wanna be there for it.
  7. #37
    I have two steelie 16s laying around if you want them jon
    but you can drag frame lol
  9. #39
    Round Rock, TX
    Thats just the fun part of it...
    The offset on the rims is way too wide...they would stick out 3'' past the fenders LOL....I need to find some stock 95 aluminum 5 spoke wheels...
    Sorry ducky, I'm looking for alum.....Thanks though
  10. #40
    FINE ill take my rims elsewhere
