My goals are:
- To actually make it
- Make a mid 12 second pass
- Not fall for the ol' "zip tie around the driveshaft" trick!![]()
My goals are:
I don't have to worry about the ziptie trick.. Even Ducky isn't skinny enough to fit under the truck, and plus you never know when a airline might blow and squash someone....Cause you know how unreliable bag'd trucks are..
Oh i forgot, along with my other goals i wanna go at least a 225 this time and pull the front left![]()
boom, if not it'll be a good show
when you run 11s you can talk smack other wise keep your mouth closed, my truck isnt gonna blow i have done everything that need to be done for insurance.
blah blah blah, and my ride will be driven this time, got an 80 now so im not worried about breakage, and we aint racin times girlfriend...first one to the stripe.
Just messing with ya buddy.
I would just like to see better than an 11.5.
